I noticed in the PV Guide this morning:
"2.1.7 d.c. Plug and Socket Connectors
PV specific plug and socket connectors are commonly fitted to module cables by the manufacturer.
Such connectors provide a secure, durable and effective electrical contact. They also simplify and
increase the safety of installation works.
Plugs and socket connectors mated together in a PV system shall be of the same type from the same
manufacturer and shall comply with the requirements of BS EN 50521. Different brands may only be
interconnected where a test report has been provided confirming compatibility of the two types to
the requirements of BS EN 50521."
So when I connect a solar edge mc4 to a panel mc4 I need a test report?
And when I connect the last panel or optimiser in a string via an mc4 to a cable going back to the inverter where I have put a mc4 plug on the cable myself then it should be the same manufacturer's mc4 or I need a test report?
I suppose I could cut the mc4 off the last panel in a string and crimp on a new one so that it makes a matched pair with the incoming solar cable. (is there an icon for tongue in cheek?)
Do the consequences of all these rules get thought through!?
