Discuss Connecting mains to armoured in the DIY Electrical Advice area at ElectriciansForums.net
Hi
I currently have a normal mains cable from the house to the shed where a consumer unit is used to connect the shed and a 3 core armoured cable runs from there to the workshop and a second consumer unit.
I need to move the shed.
The armoured cable wont reach the house. How can I connect the mains to the armoured by way of an outdoor connector. This will only be temporary so a simple solution would be ideal.
Temporary or permanent, makes no difference to the standards it should meet.
Do it right, or not at all.
P.s. sorry if it’s not the solution you had hoped for.
If your 'mains cable' is T&E, definitely not advisable.
As above, a good and proper installation is needed. If a temporary supply is needed, get someone qualified to sort it (certifiable) with a view to making permanent.
Reply to Connecting mains to armoured in the DIY Electrical Advice area at ElectriciansForums.net
Trying to find an armoured cable behind plasterboard and studding. It was used to supply power from the house but has been disconnected Can...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
