Electrical2Go - Online Electrical Supplier
Discuss Connection from 6mm to 4mm cable in the Electrical Forum area at ElectriciansForums.net
Advice needed please! I have a 6mm supply from CU to an outside box. From there, a 4mm SWA cable has been run and a Garage CU install at the other end. What is the best way (and with what) to connect the 6mm cable to the 4mm cable? Any help much appreciated. Thanks in advance
CK Tools :) The professionals choice when it comes to Electrical Tools
three words
I only recently found out the 221 series come in 2 different sizes
Ian1981
Mentor
Yes wago 221 do a 41 amp taking upto 6mm
The 41 amp push fit ones are still good tho
telectrix
Mentor
i stand corrected. never seen the 221 /6mm.
James
Mentor
Supporter
One of these on the wall?
pc1966
Are both cables already in the outside box?
Is it a waterproof box (never assume...)?
As already mentioned, why has it been left in a partially finished state?
Connecting the wires is the easier job to do, checking that it is all working correctly is something that any professional would do and requires a lot more in the way of test equipment and the knowledge of how to use it.
DPG
Caroline, any reply?
Reply to Connection from 6mm to 4mm cable in the Electrical Forum area at ElectriciansForums.net
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Top Bottom
