P
Proper Job
I am about to wire up a new conservatory , it has a pitched roof which will be have insulation and be plaster boarded. They want down lights fitted but I am unsure which ones are allowed. I am sure that I could get away with fire rated ones but they are so limited in there look, can I use standard ones or led( non fire rated) .
how do I get around the fitting them into an area where there may be insulation boards that I may have to cut into.
Oni some jobs before I built boxes 200 x 200 mm out of plasterboard before the ceiling is boarded but I am not sure how that would effect heat loss through the external roof
