Hi, got a job to connect up some new spotlights in a conservatory. Roof has been replaced and plaster boarded. I'm assuming insulation has also be installed.
Originally the client purchased Enlite Spryte non-fire rated IP44 LED downlights, however I thought that they should be fire rated as they are being recessed into the ceiling, so after a bit of research I found an equivalent model by Lap (CosmoEco - link below). Have been told space is restricted so these were the shallowest ones I could find.
https://www.NoLinkingToThis/p/lap-c...0v/6570x#product_additional_details_container
These are fire rated but only have an IP rating of IP20. Would this be suitable in a conservatory? Obviously it isn't a bathroom so usually this IP rating wouldn't usually be an issue I would assume, but as its a conservatory roof could that be a problem?
