Binda69
- Reaction score
- 0
Greetings all, just had a consumer unit upgraded and wanted your opinion before I have words with the electrician. Some stuff is obvious like the gland strip not fitted properly, you can’t just about make it ou, but others not sure off ie should the the meter tails have been fed separately from other cables also not sure why he didn’t just come straight up from the bottom of the CU. and what are those plastic connectors doing. Also he did not use a torque screwdriver but not sure if that is mandatory. Wish I’d found this forum prior to hiring him but went via reviews and checked he was registered. Thanks in advance.
