Discuss Consumer unit advice please. in the UK Electrical Forum area at ElectriciansForums.net
zdibu
Hello, looking for advice. Need to change two old CU which are next to each other. Is it better to do one or simply replace that into two new units?
One is off peak, for storage radiators. If you no longer have storage heaters then you could convert the circuits to siciets.
Haha, got it. Anyway to get rid of it I need to contact the supplier right? Who's responsible for that radioswitch? I assume that will be new meter as well.
Sorry, comes from having fat fingers and a small keyboard on the phone! Meant sockets. Teleswitch is property of supplier, they will remove it with 2 rate meter and fit single rate one.
Reply to Consumer unit advice please. in the UK Electrical Forum area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
