Discuss Consumer Unit & Boiler in the UK Electrical Forum area at ElectriciansForums.net
J
Jimmyb
How close can a consumer unit be to a boiler, currently the boiler is on the wall 150mm from the corner of the wall and the consumer is on the other wall so it facing the boiler is there any regulation about distance as i would of thought it should be 300mm between the two items
Many Thanks
Regulation 528.3.3 requires that where an electrical service is installed in proximity to a non-electrical service, it must be arranged so that any foreseeable operation carried out on the other service will not cause damage to the electrical service or the converse. This can be achieved by suitable spacing or mechanical or thermal shielding.BS 6891:2005 Installation of low pressure gas pipework in domestic premises, clause 8.16.2 states that gas installation pipes must be spaced at least 150mm away from electricity meters, controls, electrical switches or sockets, distribution boards or consumer units. There should also be a separation between a supply or distribution cable of at least 25mm for domestic pipework up to 35mm or 50mm for piepwork over 35mm.
Reply to Consumer Unit & Boiler in the UK Electrical Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
I want to know if my consumer unit (together with the digital meter) which is in a special metal container let into an outside wall near the...
