- Reaction score
- 1
Hello all, came across this while doing a eicr, looks like the cu was recently changed, just wanted to know whether this constitutes a c2 or c3, thank you in advance
Discuss Consumer unit ip4x in the UK Electrical Forum area at ElectriciansForums.net
Agreed. But without seeing a photo then both NAPIT and me err on the side of caution.If you reach live parts with a bare finger then C1 , anything else then C3 imo
Got a photo Mate?Hello all, came across this while doing a eicr, looks like the cu was recently changed, just wanted to know whether this constitutes a c2 or c3, thank you in advance
The wording on the NAPIT link is "Top of enclosure has openings exceeding IP4X/IPxxD, access to live parts" for C1. I think the emphasis is on the access to live parts aspect.If the IP rating on the top surface of the controls enclosure is not at least IPXXD or IP4X, there is a likelihood of access to live parts, which would give a C1 Code.
BS7671 is not a Mandatory Document, so it can't be mandated by the regulations can it?The wording on the NAPIT link is "Top of enclosure has openings exceeding IP4X/IPxxD, access to live parts" for C1. I think the emphasis is on the access to live parts aspect.
After all an IP3X hole with any live parts down by 5-10cm as in many CUs is hardly accessible unless someone pokes a long narrow conductive object down there. In reality there is a bigger risk of liquids being stored on top of the CU and spilling in, and IP4X would not stop that either.
So judgement on the not-IP4X size is required, as in most things.
For any CU top (or sides/bottom even) I think we all agree that the likes of the Whiska glands are by far the best solution, even if not striclty mandated by the requlations.
True, but only in a slippery-lawyer sense!BS7671 is not a Mandatory Document, so it can't be mandated by the regulations can it?
Reply to Consumer unit ip4x in the UK Electrical Forum area at ElectriciansForums.net
