• Welcome to the new forum. We're now hosted on ElectriciansForums.net rather than ElectriciansForums.co.uk - Chat about the forum upgrade by CLICKING HERE
Welcome to our Electrical Forum - We started out providing electrical advice just for the UK - But now we have specific advice for the USA too! - Register for free and share American Electrical Advice.
Discuss Consumer Unit RCBO advice in the Electrical Forum area at ElectriciansForums.net
Hi
I'm ordering a Hager 10 way split load CU and also want to order some RCBOs. I have an old house(1930s) that was rewired in the 1980s then I moved in and built a double height extension in the 1990s.
The lighting and power in old house are on separate circuits and the lighting and power in the extension are on separate circuits. I'd like to put th lighting and power old house circuits on RCBOs and also a 9.8KW shower.
I know I should be ordering Hager type B RCBOs but I heard they do reduced height ones which would be better but the only ones I can find on Sparksdirect are the type A reduced height. Also they don't do an RCBO that would be OK for the shower circuit(45 amp). Are the type A ones ok or should I just get full height type Bs? Also I assum I will just have to have the shower on an 45A MCB?
My sparks coming next thursday to do the job .
Strima
Electrician's Arms
Ask your sparks what type to order then.
Midwest
Electrician's Arms
You can't fit RCBO's in a split load CU. Think you need to discuss this with your sparks. Don't know many that would do the project this way, you buying the materials.
Spoon
Forum Mentor
Electrician's Arms
CCTV / Alarms
Trainee Access
Have you not discussed this with the electrician that is coming to do the job on Thursday?
What has the electrician quoted for?
richy3333
Forum Mentor
Electrician's Arms
Trainee Access
Yet again blinding! Given as you are probably trying to save money be aware the shorter RCBO’s are more expensive. You also have the wrong C.U.
As has benn said, ask your sparks!
Reactions: DPG
Andy78
Respected Member
Forum Mentor
Electrician's Arms
Trainee Access
Soooo glad none of my customers are like this.
TJ Anderson
Forum Mentor
Electrician's Arms
Trainee Access
Terence....Murdoch will be along in a sec with a step by step guide for install........:)
Flanders
Regular EF Member
As above You are ordering the wrong consumer unit if you are fitting some seperate rcbo , if you are getting parts yourself ask the sparks to give you a full list of parts as there will plenty of sundries, no need to get the shorter rcbos there plenty of room in the hager CUs for the longer rcbos
Midwest
Electrician's Arms
Or just get the sparks to get the stuff, unless you insist on saving £50.
Already spoken to Spark, he told me he could do this, would just use one of the RCDs for the remaining circuits and would put the circuits I wanted on RCBOs. THis is the Consumer Unit, it is configurable so why wouldn't it be able to be used?:
VML710CU - Hager 10 Way Metal Consumer Unit Amendment 3 with 8 MCB Breakers FREE, Split Load Config 100A Sw 2x63A 30mA RCCB - https://www.sparksdirect.co.uk/hager-10-way-metal-consumer-unit-amendment-3-with-8-mcb-breakers-free-split-load-config-100a-sw-2x63a-30ma-rccb
Reason I'm asking about RCBOs here is cos I wanted to order today and ccan't get hold of him at the moment.
I'm not particularly trying to save money, if I was I wouldn't be bothering about RCBOs would I? I just wanted a decent CU putting in and found a good deal on Hager . The spark has quoted £200 for fitting.testing,cert etc I'm providing CU and RCBOs. He was quite happy with this or to provide an MK CU himself but I thought Hager was a bit better quality?
TJ Anderson
Forum Mentor
Electrician's Arms
Trainee Access
£200 seems steep for an hours work!!
Electrician Talk
Electrical 2 Go - Electrical Supplier and Electrical Wholesalers
Electrical Insurance
ElectriciansForums.net (formerly known as ElectriciansForums.co.uk) was setup in April 2006 to provide free electrical advice to both professional and DIY electricians. Whether seeking advice for auto electrics, trying to find electrical installation condition reports (EICR) form downloads, or whether you're here just to talk to other electricians; we've been a first-choice website for tens of thousands of sparkies for well over a decade.
