Discuss Consumer Unit - RCBO Upgrade?? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Looking some electrical advise. I've been told by an electrician that I need to install 5 Nr RCBO's to this consumer unit. Is this correct or is the current set up ok? He has provided me with a condition report stating a 'C2' on the cables concealed in walls. If an upgrade is required will it take 5 NR RCBO's or are RCD's sufficient?IMG_0802.JPG
He has provided me with a condition report stating a 'C2' on the cables concealed in walls. If an upgrade is required will it take 5 NR RCBO's or are RCD's sufficient? ]
Without seeing the installation or the whole report its not easy to comment on the coding, usually this would be a C3 but there may be other factors to consider.
Whilst it might be possible to bodge a single RCD in instead of fitting RCBO's it is not advisable and could cause more problems.
On etching that needs fixing very urgently is the missing blanks from the front of that board.
Found one of these Ashley & Rock DBs at a house in Creggan in Derry a while back. I believe they were bought out by Hager quite a number of years ago.
I'm pretty confident you won't find any devices for it. I mounted a separate DB for work I did.
Also, although someone will probably prove me wrong, id be shocked if you can even get an RCBO for that board.
You can. It's old Ashley Rock supasafe that was bought by Hager. They based their range on this breaker pattern and it has not changed. I have had confirmation from them before that they fit and Hager give their blessing for this marriage.
The older supasafe with the red writing however are not compatible.
It genuinely amazes me how many people come on here asking questions who don't trust their electricians. Some cases they do have a point bit rarely. Still amazes me though waiting on the day a job I quote appears here
I think the board also looks like an old seimens board I’ve had trouble looking for an RCBO to fit.
Hager does fit nicely but customer is going for a board change instead
Reply to Consumer Unit - RCBO Upgrade?? in the UK Electrical Forum area at ElectriciansForums.net
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
