Discuss consumer unit relocation in the UK Electrical Forum area at ElectriciansForums.net
F
foghorn
Have a customer who's old desirable fusebox needs to be relocated as is in cupboard in bathroom with cables coming from above and below metre and main fuse metre tails all in same location move consumer box and close off cupboard my question is what type of enclosure could I use to extend cables from current location into new consumer unit located out of bathroom.
Old desirable fusebox?!
Phwoarr!!!!
Cor blimey I damn near ran out breath reading that! Where's ya punctuation! How about using a din rail enclosure to extend the circuits? Looks the mutts nuts when done right!
Cool thanks sorry about punctuation can't text on these tablet computers very well since placing this post, have located some pics of din rail enclosure must say looks good
Ahhhhhhhhhhh only messing mate!
There was a photo of a completed one in the show us your installs thread somewhere and it looked great. You could use the Line range which is linked on the right hand side of the screen.
Reply to consumer unit relocation in the UK Electrical Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Consumer unit is being moved 10 meters away from outside meter cupboard which is mostly occupied by economy seven timer thing which customer don't...
