Discuss Consumer unit under a sink.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Been to a job today to do a periodic and the consumer unit was directly under the kitchen sink. I can't find anything in the regs that says this can't be done but it doesn't seem right...can anyone put my mind at rest??
How about this then lads, not something I've found (I'm industrial) but a friend showed it me.
I would possibly put a C3 on it, alls well until the sink or waste starts to leak then it could get very messy. No really a suitable location but which was there first?
Now that has made me chuckle... :lol: Complete with NIC sticker, again which was there first? Bet the plumber was second.
Our local regs state that the means of isolation must be readily accessible. Under a sink would fail depending on the layout.
irrespective of the sink, what muppet fitted that CU at that ridiculous height. did he read the 1200mm for switches to apply to CUs as well.
If it were a new build, it would not comply with 'Approved Document M', as someone has already eluded too, because of installed height and being accessable by disable persons. But that doesn't help om an old existing installation I suppose.
Reply to Consumer unit under a sink.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
Hi, I know the regs say a metal consumer unit must be installed in all new installations, but does anyone know if the same is true of...
4K
Situation is garden summerhouse fed by own 16A RCBO in consumer unit in garage over 4mm2 (overkill !) SWA . At summerhouse this goes to sockets...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
