Discuss Consumer unit under a sink.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There should have been questions on we're the DB should be sited of its a new build, it's to building regs height so doesn't discriminate disabled persons
How about this then lads, not something I've found (I'm industrial) but a friend showed it me.
There is a whole new estate up here done like that under the stairs , only the box is above the sink.
Reply to Consumer unit under a sink.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
Hi, I know the regs say a metal consumer unit must be installed in all new installations, but does anyone know if the same is true of...
4K
Situation is garden summerhouse fed by own 16A RCBO in consumer unit in garage over 4mm2 (overkill !) SWA . At summerhouse this goes to sockets...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
