Discuss Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
ash121
Looking to upgrade the current consumer unit, it is located in the garage, the new cu will be in the same location. Having read various posts it appears that the Hager boards are well regarded but the MK boards not so
But my electrician is adamant in wanting to install an MK RCD board 13 way, he advised 13 way is a bit more than my actual requirements but it will be future proof in the event i decide to do an extension or something
I suggested a Hagar board but he dismissed that! And insisted to fit an MK board as he is familiar with them
Your thoughts would be appreciated, where does the MK board rank? Would you recommend any other CU other than Hagar?
Why does "your
Why does your "Electrician" demand that you have to change your CU? has he done any testing of the installation? probably has the one he is recommending kicking around in his Van, get a second opinion.
If he won't fit what you want get someone else.
On the odd occasion I've fitted MK boards I've been unimpressed by them but honestly If I would not be concerned if there was one in my own home.
Pic of current consumer unit attached, there is one for immersion heater and electric shower but these are no longer needed for the new CU. This one is Hagar :)
Reply to Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
