Discuss Consumer unit with lots of 20mm knockouts in the UK Electrical Forum area at ElectriciansForums.net
Hi Lewis - this little Wylex one sitting on my bench tonight. On the top there is room to cut more holes, but its too close to the earth/neutral bar, imho. It will take 11 rcbo and it's my fav with their new reduced height sp+n units.
Just cut a massive hole in the back, job jobbed........ bloody snow flakes over complicating things........ tsk
https://www.NoLinkingToThis/p/no-nonsense-fire-rated-expanding-foam-hand-held-750ml/83897
Sorted.
They must sell crates of this up in Scotland.
I seem to recall mk boards having plenty of knockouts, but I just don't like them so have moved over to Hager. Their square knockouts can be a pain or can be a godsend depending on the situation, but plain boards are readily available. Qmax hole punches make nice accurate holes as well
Reply to Consumer unit with lots of 20mm knockouts in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
