T
tedglen2
I am having my house rewired. The comsumer unit is above my kitchen door. On a house rewire does the unit need to come down to 1200mm for wheelchair use? Not sure where it would go at that height.
Discuss consumer unit in the Electrical Forum area at ElectriciansForums.net
hmmmm not sure ill have to consult the regs, but i susspect not, the fuse board is not something you should have to access as a consumer, well at least not often. and any problems/work done on it, should be done by a proffessional.
its not like switches and sockets,
one said yes and one said no : $
FFS!!, a rewire is replacing like for like, a new build or top to bottom refurbishment is a different story, however the regs say, and it is a requirement of and EICR that all switchgear is easily accessible, so with the exception of nailing it to the landing ceiling, put it where you like within reason!
It was meant with humor! :30:
Reply to consumer unit in the Electrical Forum area at ElectriciansForums.net
