Discuss consumer units in the Australia area at ElectriciansForums.net
P
Peter Woodford
Could you tell me when installing a fuse board to meet the 17th edition regs does your consumer unit have to be spilt load i.e 2no rcd breakers. Was going to install split board one side with main isolator other with 1No rcd so that not everything trips on one side.Hope you understand this
cheers
Pete
Peter,
Basically yes, all circuits SHOULD be RCD protected, so you could install a standard split load board, but the unprotected circuits would need to have an RCBO in place of a standard MCB.
This can work out fairly expensive so a 17th Dual RCD board is the best way to go.
hi
i think u can as long as u get departures from client, but dont think spilt board complies,,, sure someone will tell u if i am wrong
hi
again, knew i was wrong
Peter,
Is it not possible to have a named circuit before the 2 splits that is not rcd protected ( as long as it does not contravene other regs like buried less than 50 mm )eg a freezer radial, so that it does not suffer nuisance tripping?
Yes you can but as you have said, as long as it does not go against other regs and is clearly labeled it can be left off RCD protection.
Reply to consumer units in the Australia area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Hi, The `power went out throughout the house this afternoon but only to the sockets, the lighting circuits are all fine. I went to the consumer...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
