Discuss Consumer Unused Spare ways in the UK Electrical Forum area at ElectriciansForums.net
I am fitting a new dual CU that comes with 10MCBs. For those that are unused is it acceptable to just leave them installed but switched off and identified as unused. Or should they be removed and replaced with blanks?
I think that all unused MCB's should be removed and replaced by blanks. Others may disagree.
Saw one recently - 10 way board, 10 MCB's, only 4 in use. Talk about confusing the old couple.
dont remove them leave them fitted as may come a day you need the extra ways ,most councils now ask for a spare 40 amp to be fitted for future electric shower fitting,so no need to remove
i keep them installed, as the customers usually like the idea that they have got spare breakers.
and for my sins i keep them switched on, customers usualy only need to access the board to re-set a trip, if spare breakers are down aswell can confuse the clueless.
im sure that iff they are installed correctly then theres no issues, may be wrong
I'd remove them and install blanks personaly.....unless anyone ask's for them to be left as spare.
It is handy to go to a board with alot of spare MCB's in place when adding extra circuits BUT on the flip side if at a later date someone needs an extra circuit fitted there's a good chance i have a spare MCB in the van to use (of the right make of course) which i can charge for....if MCB is already there can charge for it (conscience wont let me)
Yes, I was thinking this too.
i leave them in, simply because it's all too easy for those stupid clip in blanks to fall out and compromise the IP rating, leaving a hole just right for a child's fingers to poke in and touch the live busbar.
Surely if your fitting a new board adjacent to it will be a circuit identification chart as required by the regulation 514.9.1 in the big green book ? So users of the installation are aware of points of utilization etc
ATB J
Tel the only place for clip in blanks is the bin they should be banned I fit din mounted always they cant fall out.
J
J
i totally agree, but most CUs come with the clip in ones or none at all. as malc. says, if the customer has paid for a fully loaded board then he gets a fully loaded board.
I always remove unused MCB's and fit blanks, as I mainly use hager CU's I have bags full of the DIN mounted blanks, they fit on just like a MCB and won't fall off.
ATB J
yep i put these with all my domestic CCU changes, as customers cant read the labeled circuits, and scam assesors always pull me up on it if i forget.:tounge_smile:
ATB J
Lucky to find a new CU labelled round here let alone a circuit chart
Yep tel I would leave unused breakers in rather than clip in blanks,they give you that stupid plastic bus bar cover to protect your pinkys when the board cover is off then provide a nice finger sized hole when the blanks fall out I would like to see the return of insulated bus bars so you just nip off the plastic where it goes in to the breaker
J
Yes of course. Not really sure what this has got to do with the thread though.
Sorry hadn't realised you were policing the forum.
My comment was in reference to how the thread develops and the need for labelling and charts, as the OP mentioned 'Identifying' unused circuits.
Next time I want to post something I will run it by you first ..:32:
J
Reply to Consumer Unused Spare ways in the UK Electrical Forum area at ElectriciansForums.net
Evening all . Just a quick question what do you guys typically charge for an rcbo spd consumer unit change 14 way . 10/11 rcbos few spare ways ...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
