Discuss CONTACTOR -RELAY RECOMENDATION in the UK Electrical Forum area at ElectriciansForums.net
hi
i would like to operate an extractor fan by dimmer switch!
i looking for relay or contactor which can work between 100v-230v!
thx
Whats that switching voltages, or the voltage of the control circuit?
why on this earth do you want to operate a fan from a dimmer switch?
hi
thx
There are loads of relays that operate on 12 - 240v. Get a TD version as a run on timer. Use the dimmer onto A1 and put your fan across N/O contacts. Go on RS and have a look.
Reply to CONTACTOR -RELAY RECOMENDATION in the UK Electrical Forum area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi is there any relays or contactors that will pull in with 0v. Just continuity. Need a pump to come on but the trigger gives no volts just...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Afternoon! Hoping someone has experience working on the ABB gear below. It’s in a Mobile Office/ Welfare unit, supplied via either 230v hook up...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
