Discuss containment question in the UK Electrical Forum area at ElectriciansForums.net
As far as I was aware cable tray is adequate containment in a plant room for non armoured cables to be ran on. I ran some 2.5mm butyl cables for immersion heaters and cable tied them to the cable tray and another electrician had stated they should be ran in armour cable as the containment isn't enough. These cables are in plain view on a tray behind various equipment so no chance of being struck by anything so can anyone point out where I went wrong. do I need to change the cables
My other concern is I have been asked to wire a workshop for a mate using cable tray at high level and plastic conduit drops to sockets and lights using t+e then running armours for the ramps and compressor by the reasoning of the electrician slagging my work this should be incorrect. has there been a change I the regs I don't know about or am I just getting old.
T/E or other suitable sheathed cable is fine on tray as long as you can establish that it's suitable for the environment.
so any idea where he is coming from as cables were adequately supported so why is he trying to tell the customer it should be in armour
to explain situation I done the controls in a commercial building plant room as he got frightened by the control panel this is how I found it
I had to alter the controls to suit new boilers (sorry didn't take photo of finished item) the other electrician done the rest of the building
he got a bit miffed when I asked for a larger supply as I was installing 6 immersions in 2 calorifiers so needed a larger supply so he ran a 16mm 4 core and terminated at the connector top right instead of taking to the isolator. he got upset when I pointed out the 16mm cables should terminate at the 63a isolator upload_2018-6-18_22-11-7.jpeg
If the Butly cables are suitable for the environment they are installed in then all is fine.
If the cables are in plain sight and do not need mechanical protection, as you have stated, then there is no need for SWA.
People have different opinions about what you can and can not do, if you beleave you are right then argue your case with him, tell him to tell you exactly what he thinks is wrong with it and see if you agree if not tell him.
Fyi i think it is fine on tray.
Tray is not containment.
Pvc mechanical protection is only suitable in areas where cables are not likely to be subject to impact of any kind.
Only the installer can decide if the cables are suitable.
If tray is not "containment" what is it classed as?
Must admit, I’ve always lumped tray in as containment.
If it’s flat against a wall, on the floor or upside down on a ceiling, it’s just something convenient to tie cables to.
Reply to containment question in the UK Electrical Forum area at ElectriciansForums.net
Some friends are setting up a metal workshop inside a shipping container, on site at a commercial building that rents out studios, workshop space...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
