Discuss Continual problems with Shower isolator. in the UK Electrical Forum area at ElectriciansForums.net
I get regular work from a student landlord. In one of his properties the shower isolator switch has burnt out on the feed side several times. I've replaced the switch twice (last time with an MK) and the shower's also been replaced. Insulation resistance on the circuit is >500 and the MCB hasn't tripped.
Any ideas?
Any ideas?
Heard this before, it could be that the Tenant is leaving the Shower switch on at the Shower, and is using the pull cord to switch it on and off under load conditions, nothing an iffy connection likes more, 8 plus KW switched many times. Try insisting they only use the pull cord as an isolator rather than a control switch. Just my take.
what is the size of the shower that it is in ?.
Bad spelling where???? Willy.
Reply to Continual problems with Shower isolator. in the UK Electrical Forum area at ElectriciansForums.net
Bit of a strange one ive been told by everyone ive called had a triton t70xr 8.5kw The water started running cold like the tco kicked in after a...
Hi! DIYer here. I have an MCB running to a cooker isolator switch. The RCD connected to this set of MCBs is tripping and isolating the cooker MCB...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
