Discuss Continuity test doubt in the Auto Electrician Forum area at ElectriciansForums.net
Thank you. In fact today I tried crimping a few times with random wires just to try and the result was quite good. I only have a wire stripper that is also a crimper, so it won't be a professional result but who cares. I didn't find eyelet connectors of the perfect size but it doesn't matter. Tomorrow I'll do the repair :)
Let us know how it goes.
Do you think it could be a good idea to sand the free ground point (at least I suppose it's a ground point) until it's bare metal? The already occupied one seems to have little room for a new connector. Thanks again
Wouldn't do any harm yes. Cover it with a bit of grease when you've bolted the terminal up.
I just cut the ground connector's wire and the conductor is damaged. I don't know if it was the wire stripper or it was already like this. Do I have to cut in Another point or can I continue like this even with a reduced copper wire section? Thank you
I'd try and cut back a bit further if there's enough spare. Not critical though.
Repair done. It seems to work fine. Now I have 4.997V at the connector, so it's a proper ground. And from diagnosis I read exactly the value of the sensor (translated from Ohm to Celsius obviously). Thank you for help guys. If anyone is interested I'll post some pics :)
Great stuff! All the best, and send a photo yes.
Here some pics. I jointed the wires making a braid and folding it on itself. Than I covered with shrinking tube and tape. If you carefully watch the engine bay you see on the left the new ground with the blue connector, and if you follow the wire you see the 1.5 meters path back to the connector. Hope it will last, seems solid.
Reply to Continuity test doubt in the Auto Electrician Forum area at ElectriciansForums.net
Hi guys. I posted yesterday about a suspected faulty starter motor.. I've had the starter out and cleaned everything up and all seems to be...
So bought a second hand Megger BM233 to practice with as I'm a college student.. So I was just using it on a loose 2.5 cable. Testing on the...
Hello, I have a fairly big property and to get power to the house, there are several metal poles with the cables running along them. I had...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
