Discuss Convert LED ceiling light to plug in in the DIY Electrical Advice area at ElectriciansForums.net
All identical to the eye...unfortunately...!!!Do any of the wires look any different to the others, like a colour trace. Is it a new fitting.
Great. Thanks. Will try the multi meter...CheersI would expect one of these wires to be earth, connected to the metal frame - you need to positively identify which one this is, otherwise powering up the light could be dangerous.
You could e.g. use a multi-meter to test between the metal and each of the wires in turn.
The other two wires I'd expect to be L and N, and probably for these lamp holders, it doesn't matter which way round they are.
All the same unfortunately....Do any of the wires look any different to the others, like a colour trace. Is it a new fitting.
Reply to Convert LED ceiling light to plug in in the DIY Electrical Advice area at ElectriciansForums.net
