123brez
hi ive just done a job today on a high speed door i have romoved the old 3ph contol panel and converted it to a single phase inverter panel that runs 16amps.
the supply is from a 20amp 3ph mcb and all i have done is removed l2 and l3 from the isolator to run the panel.
once i had set up the door it started to trip the mcb, i dont think it is anything on the door as it would normally blow the control fuse on the board.
i was wandering if i need to remove the 3ph mcb and put in a single 20amp mcb in could this be the cause?
cheers
cheers
