Discuss Convoluted Spur in the UK Electrical Forum area at ElectriciansForums.net
Hi
The garage (two internal lights, one external light and a socket) seem to run off of a internal socket with a wire running through the wall from the garage and plugging into said socket.
It was unplugged when we moved in, but suspect this was linked to leaking flashing potentially tripping it out. This is now fixed and dehumidifier has been happily running in the garage on the existing electrics.
I would like to tap into it for an additional pir led light (30w) to the front.
the existing system starts with wire coming through the wall to a junction box which has three wires out of it:
1. To a second junction box
2. One of the internal lights
3. The Single Socket
the second junction box runs to
1. Switches - one for internal lights and one for external
2. Internal light
3. External light
Is it reasonable just to tap into the first junction box for the new light? Or is this too much? I was considering adding a 13a switched fused spur for the new line, then thought should I add this to the whole ‘spur’ before the first junction?
The garage is likely to be redeveloped in the next year and so don’t want to replace the lot (unless it is considered especially unsafe).
I hope the above makes sense
thanks in advance for the help
Jim
Welcome to the forum mate.
Where goes the cable going to the garage connect to?
Does that circuit have RCD protection?
What size is the cable going to the garage and the cables inside the garage?
Wire going to the garage comes from in the house from a socket (it has a plug in the end so plugs in). The house circuit has a RCD protection.
Looks to be 2.5mm to first junction box, then 2.5mm to socket and 1.5 to lights.
As the ‘spur’ is ‘protected’ by the 13A plus I take it there’s no need for a switched fused spur?
does it sound reasonable tapping into the first junction - that would mean 4 cables coming out and one in - is this too many?
thanks, Jim
thanks, Jim
If the junction box can properly fit another cable, then there is no problems with 4 cables coming out.
Reply to Convoluted Spur in the UK Electrical Forum area at ElectriciansForums.net
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi guys, super basic question: For a room layout like this, with my understanding that a lighting circuit downlight radial goes from one point to...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
