Discuss Cooker cable size in the DIY Electrical Advice area at ElectriciansForums.net
I am not an electrician but consider myself to be very knowledgeable in installation works. Lately however, I have come across a problem when carrying out work at my home. I have supplied my cooker circuit in 1.5mm cable as stated in the 18th edition but have since had issues with my sockets. Does anybody have any ideas as to why? As you can tell I am not as knowledgeable at fault finding as I am at other electrical works!
Nice try but I'm not biting.
Where is this 1.5 cable connected from, it's protective device and anticipated loading.
thanks for the reply, it’s connected to the fuse box with all the switches on! Hope that helps
So you have connected a 1.5 cable direct to the consumer unit. What size fuse or mcb is protecting it.
Can you show a picture which includes the cable.
I cannot see a C32 mcb nor a 1.5 cable connected to such an mcb, from what I can see there is no new cable in the board. Show the cooker connection.
Reply to Cooker cable size in the DIY Electrical Advice area at ElectriciansForums.net
Hi! DIYer here. I have an MCB running to a cooker isolator switch. The RCD connected to this set of MCBs is tripping and isolating the cooker MCB...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
