I have an electrician undertaking the wiring changes required for the installation of a new kitchen. An issue has arisen because he insists on connecting my double oven (max load 5.9kW) to one of the rings - the house has two rings (each 32amp MCB). For the last 20 years a nearly identical double oven and hob (max load 6.6kW) have been connected to a dedicated radial circuit (32amp MCB) - the cable seems to be 6mm. The MCB has never tripped over the years.
I should appreciate a quick opinion as the work is ongoing.
