- Reaction score
- 57
hi can anyone recommend a cooker connection plate with good cable access when cable is coming from the top?
just fitted a click 45A cooker plate with the recommended 35mm backbox, but the existing cable was only long enough to feed via the top, and the room available was very limited even for a 2.5 let alone a 6mm cable. appears this plate is designed to be fed from the rear. anyone know of a plate with more room especially for top entry????
many thanks
many thanks
