Discuss Cooker connection unit to double socket for new cooker and hob??? in the Electrical Appliances Forum area at ElectriciansForums.net
Hi guys, just looking for a little advice.
I have just had my kitchen done (plastered and all) and had a radial circuit set up for the cooker using 6mm cable into a cooker switch down to a connection unit. It's 32amp at the consumer unit.
I have just bought an integrated single oven to find it only requires a 13 amp fused plug. I also have a gas hob that needs wiring up off of it as there are no other power points nearby.
My question is...
1- Can I change the cooker connection unit to a double socket (fed by the 6mm from the cooker switch) and use the cooker and hob with appropriately fused plugs?
Or
2- Can I cut the plug off and hard wire the cooker into a cooker switch/socket and replace the above worktop cooker switch with a FCU?
Or
3- Take a small length of 6mm from the connection unit into a FCU and then use 2.5mm from the FCU into a double socket? And plug into that?
I will get a sparky in but I want to try and get my head around it beforehand!
Jay
as above. ^^^^^^. change the CCU for a double socket. this can easily be changed back if you ever go for a higher rated hard wired appliance.
issue he may have here is that the existing 6mm cables are too short to fit a socket. maybe leave CCU as is, and joint in it to extend to a DSO.
Advice.... Don't cut plugs off any new appliances.... It could invalidate any warranty
No it don't. We've been there done that. Unless you wish to commission a new survey with all the largest manufacturers, to establish if your statement is correct. I did, at great expense to myself I might add, and only one said it possibly might.
Unfortunately, I can't remember who that was or where that thread is now. So its Russian :gun: (cutting plug off :))
Reply to Cooker connection unit to double socket for new cooker and hob??? in the Electrical Appliances Forum area at ElectriciansForums.net
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
