Discuss Cooker connection in the UK Electrical Forum area at ElectriciansForums.net
Hi I’m in the middle of installing a 2500kw cooker, I have an existing cooker circuit with 6mm cable on a 32Amp breaker with a spur coming of the cooker switch to a double socket which I assume fed the old cooker on a plug top!
My question is:
Can I replace the double socket with an terminal unit to wire cooker to?
And if so do I use 6mm cable? (same as circuit cable)
Or do I do what 2 sparks have told me to do and put a 13Amp plug top on and simply plug it in the socket spur from cooker switch? ( don’t want to do that,,)
Thank you
Gaz
2500kW? you sure about that?
2.5 kW or 2500W
Anyway.... 2500/230 is about 11A... under the 13A that a plugtop can handle.
Would be better to replace the socket with a fused outlet and hardwire the oven in.
The 6mm cooker circuit would is enough to take a freestanding oven/hob
main thing is... did new cooker come with a fitted plug? this would decide the best way.
1.5mm flex from cooker to plug.
it might have to be rated for hot environment.
have a look in the owners manual for cooker.
if you are coming off a connection plate instead of a 13A socket then 4 or 6mm would be ok.
If I put it on fused 13 amp outlet, could I still use the 1.5 flex?
Thank you
[automerge]1593027451[/automerge]
2.5 kw sorry
[automerge]1593023910[/automerge]
So 6mm from cooker to 13 amp fused outlet?
2.5 kw sorry
Sorry again ? 1.5 flex to 13 Amp outlet ?
Reply to Cooker connection in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
