E
esc
Hi guys. In a week or so I have a oven thats in need of a new cupboard/unit that houses it. The plan is to isolate securely, disconnect, inspect/test the supply, and assuming all goes well to this point, fit the new cupboard/unit and then refit and reconnect the oven, MWC. Everything is going back where it came from, theres no need to alter change or add anything to the existing circuit.
Being in a kitchen, is this particular type of work notifiable, or does it come under the conditions of say a like for like?, as for example when replacing a shower with a new one of the same rating? Which is essentially a disconnection and a reconnection.
Generally, does disconnection and reconnection of fixed euipment fall into non notifiable MW.
Also, and these matters are still not entirly clear in my mind; the whole installation is on BS 3036 fuses with no RCD protection at all. How does this affect the work mentioned above? Would i now need to tell the customer we need to provide RCD protection to the oven now that we have worked on its circuit?
Any help on this much appreciated
