Good afternoon,
Hoping somebody can help me out with this.
I ordered a Best Visso cooker hood, imported form Italy, long story but it was basically to replace the same model which I can't get hold of now in the UK.
It came supplied with a moulded two pin European plug top. After a bit of research before ordering, I assumed I could remove the two pin plug and wire a 13a UK plug top with a 3amp fuse to it. The flex on the hood is three core, neutral, live, earth. I can see no markings inside the unit to suggest the hood is double insulated therefore I have wired in the watch as suggested by the very basic manual. I notice also the body of the extractor is bonded to earth inside the stainless steel body.
Having changed the plug, the hood seems to have no power, nothing functions. It is plugged into the same standard single socket above the kitchen cupboards as the old one was, have checked this socket and it is working.
Unfortunately I didn't test the hood was working fine with the supplied two pin plug before removing it. So can't be sure it is something I am overlooking/doing wrong or whether I have been sent a faulty unit.
Can anybody give an opinion on this? Can provide more info and pics if required.
Many thanks in advance
