Discuss Cooker Switch Melting Delonghi in the Electrical Appliances Forum area at ElectriciansForums.net
Diy592
Hi,
Wondering if anyone can give me any advice.
I have replaced the Main Oven Selector switch on my Delonghi DFS 090 D0 three times and every 6 months or so it stops working and it’s melted.
The part of the switch that is melting is the bit that controls the main oven.
I keep thinking it’s the part that’s failing but this is the third one that’s melted.
The only thing I can think of and what I am looking for advice for is a while back the element was changed by a professional , if the element wattage was too high for the cooker would this cause the melting of the switch?
Cooker Switch Melting Delonghi IMG_2744[1].JPG - EletriciansForums.net
I agree,its localised damage by the looks of it,no apparent overheating visible elsewhere
It probably needed that connection made good before the switch was replaced initially
No I did not put on a new crimp, I have ordered a new one. Do you think that is all I need to do? All the connections seemed tight when I replaced the switch. Could a too high a wattage element cause this?
Difficult to say if the connector is the problem, I assume it is the bottom right on terminal 1a but it likely to have suffered damage from the heat. Are you getting a complete new wire with the connectors fitted to both ends.
No just the switch. I can put a new wire on though and try that.
The element was changed at the same time as the switch as this was thought to be the issue at first.
Is the picture of the original before you removed it because the crimp looks discoloured on that one also.
It looks as though your switch is rated 16 amp,the element for your oven 2.5 KW around 10/11 amp
As long as the element is not much over 3 KW it should handle the load
The old and new switches are fundamentally different.
The new has the link between 3a and 4a, which the old one does not. 4a on the old is connected to 1a by the jumper wire... what was 3a connected to?
Is it possible that on the old switch, the piece that broke off (I'm assuming it was terminal 3a) was connected to something else. Now on the new switch it's connected to 1a instead, possibly bypassing some other switching resulting in an overload on 1a.
Just throwing that out there :)
That said, I agree with @westward10 , the crimp on 1a on the original does have a different colour to the rest, as does the copper visible through the crimp (compared tot he others). If you look at the base of that crimp there is also some fresh looking plastic, possibly where it has melted slightly.
I connected the new switch up the same as the old. So new 3a has nothing connected?
But the new switch appears to have a spring link that connects 3a and 4a, so unless you've taken that off, it could be you're providing power to something that with the old switch was not connected.
I'm speculating because obviously it's tricky to establish what gets connected when from photos, but I think I'd be removing that spring clip that links 3a and 4a on the new switch before you try again.
I'm under no doubt the crimp(s) are the cause of the repeating issue here, when you overheat metal it changes its properties and with crimps it makes them not fit for purpose, you need to try get hold of some pre-crimped wiring looms for the appliance, you will not have the correct crimps and/or crimper to do this kind of crimping, If you were to buy one it would cost you more than the appliance itself, you cannot cut corners on high current high duty connections like this (with regards to the CSA of the cable), I see it all the time with previous attempts with budget £30 crimpers causing the problem to reoccur.
agree, but i see it loads of times on factory fitted spade crimps. notably on catering equipment. must go to a certain pub at least once a month to fit new D/P switches and burnt 0ut crimps on carvery warmers.
I would say Tel its down to the quality of the factory provided crimps, after time the crimpers need calibrating or they can suffer mechanical drift and wearing down, as this is often massed produced in poorer countries with sweat shops making up the wiring looms then after a few years the quality of the final crimp suffers, it is also brand dependent, some are well aware of such issues keep on top of it with regular checks and calibrations.. add to that the quality of the crimps themselves that only have to be out by a fraction a mm and no matter how good the crimp is done the final connection will fail - spade connections speed things up in manufacturing but this is a downside of the process.
Reply to Cooker Switch Melting Delonghi in the Electrical Appliances Forum area at ElectriciansForums.net
