Discuss Cooker switch in the UK Electrical Forum area at ElectriciansForums.net
SensesFailYou
Well I went to price a job yesterday changing a consumer unit and installing the main protective bonding conductors. So everything is A ok but when it comes to the kitchen it's very small, has a built in fan assisted cooker, pull out cupboards and nicely tiled so that sets the scene. The cooker switch is behind the plinth on the floor which then feeds the hob, fan assisted oven direct from the isolator and the on board socket is powering the fridge. Now there's no real place to put this and removing tiles to place it above bench would probably not be an option but I'm not happy with it on the floor behind the plinth which easily comes off. Would this be an observation on the test sheet for the DB change if the customer didn't want to move it? The only option I can see is to move it and place it in the cupboard above the fan assisted cooker but it would have to go at the back as its a high up cupboard etc and by the time they fill the cupboards it would be a bugger to get to n the event of isolation. (I put all this kind of stuff to the fronts of the cupboards for easy access)
also I believe the socket for the washer is behind the washer!
any thoughts would be appreciated cheers guys
It may not be ideal but if you are 'just' changing the CU and bonding why are you concerned with these items?
Cooker switches aren't mandatory so it doesn't really matter where they are.
Millions of washing machines are plugged in behind.
Cheers for the reply! I'm a sucker for trying to save the world so to speak I like things to be done properly and this isn't the done thing with regards to the cooker switch but like you say why concern myself and give myself more work! Always concerned the NIC inspector wouldn't be impressed with little things like that. As for the socket behind the washer I understand what your saying obviously on a Rewire or newly installing it you wouldn't do it that way, but on something that's been there a while there's not really much you can do.
Cheers buddy appreciated!
Reply to Cooker switch in the UK Electrical Forum area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
