Discuss coolant temp sensor > is polarity important? in the Auto Electrician Forum area at ElectriciansForums.net
jomo64
Does it matter which way you connect the 2 wires to an engine's coolant temperature sensor?
Does the thermistor inside the sensor have polarity?
I do not know the pinouts on the car's temperature sensor and I do not want to risk damaging the car's computer.
Thanks in advance.
A thermistor generally has no polarity, however it may be that there is more inside the sensor than just the thermistor. I doubt it though. Has the sensor got a part number? What make is it and what make is the car?
As above, thermistors have no polarity.
However if it is a thermocouple then polarity is important.
It is unlikley to cause any damage but will work backwards, I.e a rise in temperature is seen by the control or gauge as a fall in temperature.
If you get exactly equal resistance readings on a meter with the meter probes either way round, that fall significantly as you increase the temperature but remain equal, it is probably just an NTC thermistor and polarity independent. If the readings are unequal or do not vary with temperature, then it is either semiconductor based or an NTC with interfacing electronics that will be polarity sensitive.
Damaging the computer is un-likely ,as
most inputs/outputs are protected from many eventualities...
(un-less already on its last legs)
Getting plenty more error codes by loading a supply rail that has several other sensors also attached (More likely) !
Thank you very much for your reply, Zap.
The car is a 2005 Australian Toyota Hilux 2.7L petrol engine model TGN16R
I don't know the part number of the original temperature sensor, but there are several suppliers of replacement sensors, one of which is part number CCS52
My understanding of the scheme is that the Hilux's ECM (computer) supplies a +5 volt reference signal to one of the 2 pins on the sensor and an ECM ground to the other pin. The ECM then monitors changes to the resistance of the sensor.
I have heard that on some cars the coolant temperature sensor has a 2-stage temperature/resistance graph characteristic - I do not know if that implies that there could be more componentry inside the sensor (e.g. diode?)
Thanks.
From what you've said I wouldn't risk it. Can't be certain it is just a thermistor.
Reply to coolant temp sensor > is polarity important? in the Auto Electrician Forum area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
Hi All, Weird matter happening here and I hope you can help! My 3 Pahse EC Fan is connected to a sensor and a controller for the temperature...
Hi, I've recently done a PAT course after the large company I work at discovered we have a Deltapat 3309 kit tucked away. I'm actually an...
