Discuss Core Drill for Bathroom / Kitchen Fans in the Electrical Tools and Products area at ElectriciansForums.net
W
WarrenG
Any suggestions for a core drill to fit an extraction fan in a bathroom or kitchen??
I have been told that a diamond core drill is needed?
Any suggestions would be appreciated.:)
Warren
Lew1s,
Yep any size indications would be appreciated.
Is there a standard size that you can buy for standard extractor fans?
it all depends on the size of the fan you intend to fit,your probably better off hiring one and the drill for the day though,not very expensive
Bathroom fans tend to be 4" and kitchens can be up to 6" dependent on where they are sighted. Unless fitting them day in, I'd hire them from HSS and put it on the bill.
if you want to drill a hole for a 4" you will want a 110mm core drill as core drills sizes are out side size and any pipe is sized 4"inside dimentions
If you have a choice, get a "thinwall" core bit (as opposed to thickwall) if you're just coring the hole in brick and block. Much less effort, quicker, and easier on the drill motor. I tend to core slightly bigger than 4" to accomodate screw heads, duct strapping, etc, that might also have to slide back in the hole as an assembly with the damper cap. If you drill a hole "exactly right", you'll end up cursing yourself. Most of the damper caps will cover up to a 5" hole.
Some of my friends have had decent luck with the grit-type hole saws in brick and block, but for just a few dollars more you can get a proper carbide toothed core bit. Difference between toys and tools.
If you're looking for a tool hire co try Brandon tool Hire . I find HSS over priced. I have my own set as I often have to core cut for waste pipes and the like and if you were going to charge extra for hiring one why not buy one try screwfix etc and pass the equivalent hire cost on Getting the punter to pay for your tools is a rather good idea I think!
Maybe worth buying a set, when you consider the time involved to collect and return kit?
Will see if I can find a set with the standard fan sizes (i.e. as Beaver74 said 4'' 110mm)
Thanks for the replys.
i got a 6" 150mm core cutter for £35 which is fine for 6" fans, but if you use the flexible ducting kit to go from the back of the fan to the external flap cover then it requires a hole of 167mm for the ducting. If you go on screwfix they usually have the installation instructions online in a PDF for most of the fans so you can see what size holes are required
Thanks experience, I will take a look as a size guide. I'm thinking that the best bet is to probably buy some of the more standard sizes, i.e. 4'' / 6''
If you're looking for a tool hire co try Brandon tool Hire . I find HSS over priced. !
They sure are I prefer to buy my tools though even if I only use on occasion
Hss are dear but definetly hire one as u need one with a slipping clutch, as if you don,t and that drill snags, i hope your shoulder or wrist hold out as it don,t arve urt man.
My SDS drill that i use for core cutting is a Ryobi 650W currently £39.99 from screwfix. Have done a lot of Ex fans box chiselling etc. 3 1/2 years old and now realise That if I'd greased the SDS connection it wouldn't be squeaking at me now. that drill has made it's money many times over and has clutch hammer and normal . You could do a lot worse.
I've never heard of Perles but bear in mind you'll need a transformer as well. It wont chisel so you'd have to buy another one for that if you do any chasing( it's not SDS, therfore has no rotostop) I would only buy powertools that I can take back the same day if there's a problem. How cheap can this be?!
Hi just came across this thread although its a little old I wonder if someone can advise me. I have to use a core drill to fit a fan in a flat where i can put the cover on from a window but drilling from a ladder is out of the question.( I know it should be anyway) Does anyone know how much mess of the wall they make if you drill from the inside out or will the vent cover up any splinterings. Anyones experiences would be appreciated.
Shouldnt make too much mess, Use a hole saw bit to get through your plaster then once on the brick use your core drill. Always drill inside out anyway.
Reply to Core Drill for Bathroom / Kitchen Fans in the Electrical Tools and Products area at ElectriciansForums.net
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
