Discuss Course questions in the Industrial Electricians' Talk area at ElectriciansForums.net
M
MICHAL830125
Hi
I have little problem with questions from my course for C@G 2330 level 3.
I cant find answers anywhere, buuuu...:confused::mad: :)
please help:
question 1:
what is the recognised practice for the supply to a new installation whose assessed demand is expected to be greater than 23kW? To install:
a) A 50mm 2core PVC/SWA sub mains cable
b)A 3 phase supply
c) 50mm meter tails
d) a 200A BS1361 fuse in the service cut out
question 2:
Earth fault loop impendance (Zs) test: When conducting a Zs test on a ring final circuit, the Zs readings taken at the socket outlets gradualy increase toward a particular outlet, then gradualy decrease moving away from it. This is baceuse the socket having the highest Zs reading:
a)has a loose connection
b)is the closest one the midpoint of the ring
c)is a non-fuse spur
d)is the furthest one from the midpoint of the ring
question 3:
Determine the actual Zs of a A3 radial circuit wired in 2.5mm PVC/PVC flat cable having a 1.5mm CPC it is lenght of run is 40m and it is installed in a location that will never exceed 30C. The value of Ze is 0.35 Ohms.
a) 1.32 Ohms
b) 1.16
c) 1.13
d) 0.37
thank you for any help.;):confused:
do u attend college i am currently attending college for my level 3 also now i know my notes will cover all those questions but why have your lectures not explained this to you....?u need to go and speak to them especially if your paying and thy are not teaching you
Hes right mate, get the tutors to help you understand what your meant to be learning, giving you the answers won't do you any good in the long run.
mate your paying your hard earned brass for these tutors to teach you sit down and explain to them your that your not understanding and dont be afraid to hold the class up and take notes i take loads of notes because you miss loads in class i go home then and type them up neat so when it comes to revision its all in order.there are some lads on my course who dont even bother bringing in a pen i cant be doing with them cos they stop the likes of me and you learning keep up with it maybe look and buying a course book from amazon think its about 8-9 quid for the l3 book
Reply to Course questions in the Industrial Electricians' Talk area at ElectriciansForums.net
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Hi Guy's, I'm revising for my 18th amd 2 and came across a question that has me a little confused. I think its probably the question is badly...
Hi I'm currently doing C&G 2365 Level 3 I'm working through the 305 design assignment (Swimming pool, hotel etc.) Other then this assignment I...
4K
Hello everyone I'm Chris. I am taking the 2391 in February. This question is from the c&g main site under 2391 sample questions. Continuity of a...
4K
SORRY FOR LONG POST. So i have my 2391-52 multiple questions coming up on Friday 13th, ( yeh i know) and was giving some things to study over by...
