Discuss Coursework-HELP PLEASE!!! SHEET 2 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Delboi1992
Hi everyone I will be posting a lot of questions here in the next few hours I would really appreciate it if you can tell me most of the answers as I am not getting far searching on the internet.
1. Give an exa mple of a reasonably modern develo pment in plumbing systems that has become a major cause of co ncern with bonding. Explain your
reasons why.
2. What is temporary bonding? Give examples of when and where it should be used?
3.
Imagine you have been asked to carry out a repair job on an existing heating
system. Write a short report on:
how and what you checked to ma ke sure that equipotentia l and
supplementary bonding was correctly installed.
what you did so that a section of pipework could be safely removed.
Hi
1. Plastic plumbing pipes, these cannot import a potential into an area so thought has to be given to whether or not bonding is required.
2. Temporary bonding is used when removing pipework or equipment to keep the gas/water/oil pipes equipotentially bonded.
3. 7 or carrot
Visual check that clamps and screws tight also testing the continuity from the MET end to the bonding clamp.
Has to be measured with cable removed to avoid parallel paths effecting the result, (removed MET end to bonding clamp).
Expect a low reading ie 0.02R depending on length of cable. If doing this isolate supply to avoid any risks.
Supplementary bonding connects all metallic surfaces in an area to avoid shock, ie the taps being at a different potential to the radiator.
Bridge the removed section with temporary bonding as 2.
Any help?
Reply to Coursework-HELP PLEASE!!! SHEET 2 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
Background: I have a ex council 1st floor flat that I bought, I moved in to care for my disabled mum and so rented the flat as I could not do...
5K
Hi everyone I will be posting a lot of questions here in the next few hours I would really appreciate it if you can tell me most of the answers...
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
Hi guys sorry just a few more questions i need help on much appreciated. 1.What do we mean when we talk about ‘decommissioning of electrical...
