Hi all, I was testing an installation today and every thing seems to be in order till I found a piece of white pvc conduit with a single 2.5 brown cable in it with no cpc. The conduit had been installed to pick up a permanent feed to a PIR from an emergency light fitting.
Both lights and the PIR were all earth correctly Just not through this conduit link. Now my question is, is this allowed? If I was running the cable I would put a cpc in there as as it forms part of the circuit it should have a cpc. Is there a reg relating to running a cable this way. Of course if the conduit got damaged there would be no earth path via the conduit, so the cpc may pick up the fault but there is no guarantee that the cpc and the live conductor would be damaged at the same time???
