I’m in the process of creating a jewelry box in solid oak, where the lid of the box acts as a mirror. I’m exploring the possibility of adding LED lighting into the mirror the same way it's done with a lot of other vanity mirrors: https://www.amazon.com/FUNTOUCH-Rec...keywords=vanity+mirror&qid=1610707996&sr=8-39.
I want the lights to be powered by USB (which would make it 5V LEDs from what I understand), to avoid the multiple-different-power-connecters issue. It would be great if one could dim the LEDs to different brightness levels and it would be nice if one could choose between different light levels (different K-values), but these two things are not a necessity.
I've read up a bit on LED lighting on - Learning Center | Waveform Lighting - https://www.waveformlighting.com/learn - but I'm still very new to LED, so I have a lot of questions that I was hoping you could help me out with:
I know that was a lot of questions. I hope some of you can put me on the right track.
- What do I need to create different brightness levels for my LEDs?
- What do I need to create different light levels (K-values) in my LEDs?
- Do you think the aforementioned mirror uses something similar to LED light strips - CENTRIC DAYLIGHT™ LED Strip Lights for Commercial & Retail - https://store.waveformlighting.com/collections/led-strips/products/ultra-high-95-cri-led-strip-lights-for-commercial - behind the glass?
- To diffuse the light, would it be enough to simply sandblast the surface or what would you do to diffuse the light properly?
- Where would I go about buying what I need for a project like this?
