M
midgetman
i need to extend 2.5 t & e. If it is crimped / heat shrink and capped is it ok to then be plastered over.
thanks
thanks
Discuss crimped extension in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I had a NAPIT assessment a few months ago.
The assessor stated that thru crimps and heat shrink was ok.
I disagree,
but I'm sure he knows best
As far as I know ratchet crimpers are not designed for solid core cables,
I feel that the maintenance free connector blocks would be a better way to go
Was told this was ok by elecsa when i quiered this, as classed as mechanical joint also told you must write down on any test sheets position of joint.
Reply to crimped extension in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
