Discuss Crimping lateral mains in the Australia area at ElectriciansForums.net
J
jamminuk
Hi,
Anyone here see any problems crimping 16mm lateral mains as a repair as opposed to re-running a complete new cable? I'm talking line, neautral and earth for 12 flats, 60Amp fuse. Junkies keep on nicking all the cable.
Jammin
If your using exposed crimps and heat shrink id be inclined to finish the joint of with self amalgamating tape(waterproof/moisture proof) or/then cloth tape also
Just to add these cables are run in metal trunking, not sure if that makes a difference. I suppose what i want to know is, is it against regulation doing it this way? Someone mentioned something about bad practice.
Ben
I suppose a new cable is the best option but the new ammendment in the regs says we can bury joints in a wall if the joint is made with a mechanical tool, i.e crimps
By far, ...better to enclose overall, in an adhesive headshrink tube. Those tubes when cooled can be as hard and as thick as PVC conduit, but will be sealed both ends against moisture etc!! Not that expensive either!!
Whats the regs about crimps and heat-shrink?Do you need to heat-shrink insulated crimps?
No you don't have too, but i always do, and in the appropriate colours too.... Some insulated crimps have heatshrinkable insulation as the insulated cover, but i still over cover with coloured Heatshrink
Reply to Crimping lateral mains in the Australia area at ElectriciansForums.net
Hi, Can anyone tell me what material the main supply cable is wrapped with (I believe this cable is owned by the DNO). My concern is whether it...
6K
Hi there, Does any one know what kind of insulation resistance to expect for pink fibre wall/ceiling insulation? I'm trying to figure out if the...
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
Post a sizable tree branch puncturing my flat roof and ceiling in what is a converted garage, I did still more damage in my efforts to repair the...
