- Reaction score
- 133
Hi all, i hope this is in the right section (if not i do apologise and will not do it again).
I need some help with a very problem customer, I have carried out a c/u change and issued a EIC, then 2 weeks later I get a phone call blaming me for the boiler not working, called to the address and found the boiler controls had no output. So replaced them and checked all the operation (all working fine). No heres the pain in the bum bit. Got another call (4 months later) to say that ever since i fitted the controls the heating system doesnt work and their plumber has said that the controls were the problem, i went to the property and checked all the wiring and found the thermostat that is on the side of the hot water tank wasnt shutting off. Went back to the customer with this information, had another call saying that the plumber had got his electrician in and that he redone the boiler controls and now everything is working fine.
Sorry it's a bit long winded but, im having difficulty explaining to the customer that what i done was not wrong and i wasnt given the chance to be there when the so called electrician repaired the wiring. Anyway this customer is now trying to say that the EIC i issued should cover the boiler wiring even though i havent tested it. And that the EIC is a gaurentee (sorry for bad spelling) for 3 years!!!!.
Many thanks in advance
Chris Hughes
Chris Hughes
