Discuss Customer wiring own electrics in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Hey guys
Went to a customer today who wanted some electrical work looking at. Turned up and he showed me a granny annexe he had wired himself. (He has assured me he has 30years experience in the industry) he now wants it testing and certifying and a part p certificate issuing. I’m not comfortable with putting my name to the install and doing an electrical installation certificate. What would you do in this situation and what are his options.
I can’t see how he couldn’t have notified building control of the works as it’s a two story building. Do you reckon they would accept an EICR? Could be worth a phone call.
Unless you were involved with the job you can’t really adopt it as your own...
I know people have do taken on near complete jobs and have seen this done but it’s not strictly correct
The guy should have really notified building control ahead of time not after the fact
Would an EICR be the only way forward now as I can’t see any contractor signing the work off as their own. Would building control send someone out to do the relevant tests to get their part p certificate. Not sure what’s best to advice him going forward apart from stop being a tight arse and getting a spark in to begin with or if he is a spark get his own registration.
"I'm sorry that's not a service I offer or am interested in offering"
Is my usual professional alternative to "Would you turn up at a restaurant and hand the chef some spuds and a steak you cheeky twunt ?"
There is a 3rd party certification scheme run by Napit and Stroma (I think).
From what I understand, you have to be registered with them to conduct 3rd party notifications, and the ‘certificate’ issued is some kind of EICR.
Just quote for a EICR, if he accepts the quote just do that.
It's not your problem if the councill accept it or not, he needs to sort that out for himself.
You can't sign it off so that's a non starter.
Yes
There is an option to employ a sparks to act as a 3rd party when it comes to notifying Diy electrical work.
However this should be done during the project so the sparks gets to see the wiring as well as the finished job.
This OP sounds like the job is all finished with no way to see the actual wiring.
You could in theory drop off all the accessories and do a thorough eicr and notify the job as your own , if the money is right
Every other certificate apart from an eicr asks for designer, installer and tester. You can’t put your name to the first two.
Probably why the others are certificates and an eicr is only a report.
Agree with above. Do it as an eicr and it’s up to the customer to get his P
Just think about what would happen if you fully signed it off and there’s an incident soon.
Creeks and paddles spring to mind
You can't even go down that path now it's too late.
The only test and inspection is an EICR.
Even with the EIC and he signs off design and construction parts you can do the testing but no inspection part. It' what you can't see.
I take photos of my 1st fix so possibly the guy has done the same..
If not floor boards will need to be lifted for inspection.
This may well satisfy building control for the installation methods.
Design is easy enough to verify along with testing too.
Can’t do an EICR on a brand new installation that has never been certified to start with
Unfortunately that's how most BC offices approach the regularisation process.
How are the Napit/Stroma 3rd Party certifiers covered, if they’re only testing and notifying the work without seeing how it was installed? Do Napit/Stroma exempt their 3rd party notifier contractors from any prosecution etc?
Reply to Customer wiring own electrics in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
This is a strange one, my neighbour is a bit mad, he had a largish extension built in about 2015, the builder attempted to do everything including...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
