Discuss Cut out and meter connected with t+e in the Electrical Forum area at ElectriciansForums.net
Bellendian
Been to look at a job today....cut out at ground level, meter at ceilling height,in a wooden boxing and the pair are connected via 16mm t+e!!
CU cover missing, and a helpful scribbled note on the wooden access panel ' live parts inside, only qualified electricians to open'!
So...who to call...supplier or DNO?
Rough as though! To be clear this is t+e between cut out and meter, not meter and cu.
Seen plenty of cu's fed by 16mm t+e, not come across t+e 'tails' before, maybe I've been lucky!
Reply to Cut out and meter connected with t+e in the Electrical Forum area at ElectriciansForums.net
