Discuss Cyp cat 5 cable problem in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
ses
Hello
I have a customer that has a CYP 1H2HBTE system
With a sky plus hd box
The system has two tv sets in different rooms
I was asked to check the cat5e rj45 connections between the transmitter and receiver for the lounge and the connector seemed a bit loose so i said i would put new rj45 plugs on the ends
However once done this stopped working completely
I spent 5 hours with 3 types of RJ45 cat5e plugs and 3 sets of crimping tools trying to get this to work again but to no avail
Ive used my cat 5 tester to check my connections and all ok
I purchased a pre made cat 6 patch cable and it all works again
The cat 5 rj45 plugs seem loose when connected to the equipment
The cat 6 patch lead is nice and tight when fitted so i can only think my connectors are too small or not making contact properly
Can someone help me im a bit out of my depth now
Can cat6 rj45 connectors be slightly bigger externally?
Is there a special rj45 for this equipment
Help
Just a cheap one not anything expensive
I did think maybe its the existing cable and my connections may not be solid but ive run cat 5 for internet connection cctv before and never had a problem terminating rj45s
Thats the only thing i can think of that maybe it needs a cat 6 plug
My patch lead is cat 6
The existing cabling is run in cat 5
Is there a difference between the plugs?
I believed it was just internally the pins are staggered to allow the cat 6 thicker cabling?
Reply to Cyp cat 5 cable problem in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Running an Ethernet cable to my outdoor studio. I did this successfully before using cat 5 but cable severed. Run a new cable cat 6e. This cable...
Hi everyone, I'm looking to do some cable runs for cat6 etc in my house and was looking for some advice on blind wiring. I'm not skilled but I...
Hi, I have bought a new house. It has coax cables running to pretty much all rooms. I would like to replace these with cat6, and install new face...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
I'll try to make this quick... A month ago the taillights all went out, checked the fuse it was blown and replaced it. A couple day later they...
