Discuss Dali lighting help with issue in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
I've installed 2x JCC71361 Dali LED panels controlled via an EX-OR lightspot HD PIR.
I seem to be having a real problem with it. The customer complained one of the fittings was flickering ever so slightly. I went back and indeed it was lightly flickering. I swopped the control gear over but the same fitting flickered. I rang JCC who said it must be a faulty panel. However, it's been replaced (and a new driver) and now both are lightly flickering.
Any ideas what this could be? It's driving me crazy. I've tried looking through the parameters of the PIR using the remote control but nothing seems to be obvious.
Just double check those setting with data sheets for the driver and the fitting.. very common for the fittings to flash for a mis-match..
Are the new drivers a line for like replacement?
If it is not the above as helpfully posted on here we have had this same issue with CP Electronics Dali dimming PIR's where the lights have been flashing it is to do with the natural light coming in a simple reprogramming and it should be sorted.
Reprogramming? Maybe turn the light adjustment off?
It's a slightly different driver. It's a DC Maxi Jolly. It seems to be capable of powering the fitting.
I'm still unsure why JCC have said it needs to be 1,2 and 3 in the on position. That's 48v (sec) 850ma and 650ma.
Seem right?
Reply to Dali lighting help with issue in the UK Electrical Forum area at ElectriciansForums.net
Good morning all. I have an issue with some dali lighting. Basic system as far as i can tell. Dimmer, controller and 8 button switch. No other...
5K
Hi Guys, I love colorful LED light strings. I've been wanting to hand some around the house and finally got around to it. I purchased a few LED...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
