Discuss damaged swa cable in the UK Electrical Forum area at ElectriciansForums.net
C
currie123
hi,
had a customer call me after he put a spade through his armoured cable supply to his garage, wants me to joint cable undergroung which is fine i thought, obviously using the appropriate jointing kit etc, but now he has asked the question if a socket could be added at the damaged point of the cable (as oppose to jointing it underground) , and fixed to the wall beside it, obviously this is not common practice but cant think of anything wrong with this providing the garage supply cable is rcd protected and cable is appropriately sized and correct size of mcb at the fuseboard.havent been to the job yet, but i am guessing a 6mm 3 core and 32a mcb set up.
any thoughts?
Just seen breaker size you need to check personally I wouldn't do it now you can scotch cast this cable or you could run a new swa in would it be easy to run new cable in and give him an outside socket from another circut
scotch cast?? ok mate thanks i wouldnt be tool keen on doing it either but when i thought about it i wasnt sure why it wouldnt be possible
customer reckoned there would be enough spare but im not sure, dont think its a great idea anyhow
If he's cut burried SWA cable with a spade he must have strong muscles, but seriously you'd need a good "extra" 1m to bring it to the surface, terminate twice and rebury so exactly how deep is it?
Without looking it's hard to say, if there's enough cable MF IP67 junction box which will allow you to spur off for the socket (SWA rated to take =>32A).
And tell the gorilla to put his very sharp spade away...
Not as deep as recommended in regs anyway! Seriously I'm going to check the job tomorrow and take it from there, I think if he's keen on an outside socket il give him a quote for putting one in a more sensible way, and joint his armoured cable underground suitably! Thanks
If the area is prone to water saturation then you'll have to go the full IP68 route, seen a couple of installs recently that were fine until the summer came along.
I'd agree, use a torpedo, then back in the ground and run a separate circuit via swa to supply the socket.
I can't see how there would be enough spare cable to provide a socket above ground, unless you use a resin Y/T joint and insert a spur.
Reply to damaged swa cable in the UK Electrical Forum area at ElectriciansForums.net
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb...
