Discuss Dangerous Situations Report in the Electrical Forum area at ElectriciansForums.net
....Then you need to change your litter more frequently.Yes, every time I come out of the toilet!
I was looking through all the certificates on the napit site and noticed them..
Didn’t know they existed and thought they might be useful
www.hollycroftsoftware.co.uk do one. I have used Hollycroft for many years and are brilliant!Hi Charlie, they can be a useful tool. Like all certification is more about covering you're own back. A test cert of any description is like an insurance policy if filled out correctly.
If you have the need to fill out an Electrical Danger Notification you may also may need to isolate circuit ect. thus if the case an Electrical Isolation Certificate would be recommended to be attached especially if you are leaving the job.
Also useful if doing a first fix on an existing installation eg a kitchen refit where other trades / people are involved (who think they are electrically trained and switch on the eg socket circuit to put the kettle on and end up electrocuting someone).
I don't know of a certificate software that do one yet but I'm pushing for it. In the mean time I've produced a simple excel sheet which is set out similar to other well know certs. The basics follow similar to what I have filled out on some large site that I've worked on in the past.
Please find attached.
Hi @Top Cat just had a quick check on hollycroft couldn't find a Electrical Isolation Certificate, though could find the Dangerous.www.hollycroftsoftware.co.uk do one. I have used Hollycroft for many years and are brilliant!
Have only used it a few times but it seems really good. If you do get it go through it a few times practising as the first time I kept forgetting to put in some parameters!Hi @Top Cat just had a quick check on hollycroft couldn't find a Electrical Isolation Certificate, though could find the Dangerous.
How do you find there calculators for cable sizes ect, been trying to find a sensible priced one for years. Cheers
Reply to Dangerous Situations Report in the Electrical Forum area at ElectriciansForums.net
